After finally finding the culprit of noise that eluded two shops and changing a ball-joint I checked my nuts and seen one very loose. With the air ratchet I began tightening and this happens. Did I over-torque or was it already stripped when they rebuilt my diffs and it didn’t take much for it to come out.
Leads me to my next question…are there stronger studs I should be using instead and what’s the damage aside from probably tapping the hole for good measure. I think Joey makes something to keep them from walking out but what else is there.
Off topic but the noise I had only happened while loading the front left corner of the truck and it was a metallic clank.
Once I pulled off the steering stabilizer I put two and two together and figured the ball was maybe damaged a bit when the steering gear box and and pitman arm was changed.
