QuackAxel
Seems to cheap to be quality. Looking to only do this once.
16400-66081 Aluminum two row. Not cheap but discounted if purchased online.Seems to cheap to be quality. Looking to only do this once.
While I have never gotten a compliment from my Ron Davis, but i was truely impressed by how well it performed over the past 4 yrs of ownership...RIP RD.It fits all FZJ’s, that’s why I posted the number. I run it, many run it. The older number is most likely copper/brass construction. Run Aluminum. If you want to impress someone with your radiator buy a Ron Davis.
If they were just a little more reasonable I would bite! But 4 times the price of OEM? Do you see 4 times the benefit?While I have never gotten a compliment from my Ron Davis, but i was truely impressed by how well it performed over the past 4 yrs of ownership...RIP RD.
Nothing about this sounds like by-passing the water on oil cooler is a good thing. More than anything, a water on oil cooler does a very good job of stabilizing the oil temp quickly, much quicker than an air to oil cooler. The coolant in a radiator sets the oil temp to where the air on oil cooler can finish the job of keeping the oil temp somewhere with in the realm of warm enough and not so hot that the oil becomes overheated.I went ahead and bypassed the radiator using a Deral stacked plate cooler and autometer ATF temp gauge...hot at idle between 120-150 degrees. Temps rise very fast at stop lights. Moving she runs down to 80 degrees. This is Calfornia weather.
