Vossie
#thecrazycruiserman
thanks for the input. Ive been going back and forth between old school gauges, an OBD2 and the dakota. I really want the dakota, its just on the pricey end. but I guess its well worth it.Thanks! With the additional power I don't think I'll need to regear. Tundras without tow packages came with 4.10's, with tow packages 4.30's. They weigh a couple thousand lbs more than I will, so I don't think I'll have any issues with this setup.
I certainly got lucky with that truck bed. I like the length of SWB 45's, but I don't like the look of them. I think the LWB's are too long, and have too much rear overhang. With this setup, I'm able to combine the two and make it how I want (hopefully).
The tank will not fit in the factory 80 spot any longer due to the length and width of the new drivetrain. It will be sideways behind the rear axle. I actually just got it back from the radiator shop.... they boiled/cleaned it, and I was able to get the 3 new seals from Toyota for the filler, evap, and pump.
I am excited to use the 80 setup though. I like the size, the fact that its metal, and I can use the OEM steel skid plate.
Thank you! Definitely go with the DD. The OBD stuff is nice, but I don't feel like it's quite there yet as far as every day driveability.
