We also got the crown jewel back from the powder coater this morning and made a beeline back to the shop to install…
are you using the original cab mounts. looking for the one under driver seat. looks like a big letter X. spot welded to tub with a stud that will drop into frame mount and bolt down. any leads. also need transmission tunnel or floor pan. any advice.We also got the crown jewel back from the powder coater this morning and made a beeline back to the shop to install…
Hit up the classifieds if you're patient, if not try vendors like SOR and Classic Cruisersare you using the original cab mounts. looking for the one under driver seat. looks like a big letter X. spot welded to tub with a stud that will drop into frame mount and bolt down. any leads. also need transmission tunnel or floor pan. any advice.
I got zapped too way down here in the satellite shopThis is where things get blurry. ETAF downloads a message from the mind expander and points to a cut off piece of water outlet.
