asutherland
VA7 HDT
Cool, keep us updated =)
Good call Douglas, agreed.
If only a section of harness is bad and it is easily accessible and it is obvious that it was damaged through some sort of mishap, I would just patch up that section rather swap out an entire harness.
the most expensive was the broken nss harness around the plug so i'm hoping that fixes my reverse light problem
new sensor / switches at the rear and cdl, new wire harness from the rear lock to the rear ds harness, new wire harness from the cdl to the firewall and the problem seems to be solved.
thanks for everyone's help.
looks like i'm ready to get myself into trouble.
Does anyone know where the 4wd ECU is located on RHD 80 series? Specifically 95 HDJ81? I have been behind glove box and in both kick panels and the 4wd ECU has not presented itself. Any recommendations appreciated. A copy of the service manual, I would certainly buy if I could find it. Thanks Legendsi'm missing something here, where is this 4wd control ecu? i was assuming it was the silver box in the ds kick panel in front of the transmission ecu (the smaller cig pack shaped box modified for the pin7 mod).
i have the manual above which doesn't seem to show its location but i also have a '96 manual which indicates in the ds kick panel.
im looking at the wiring harness and female end in the ecu and they don't seem to jive with the manual picture. does the manual not show that this plug has 16 wires or at least 16 terminals?
Pull the plugs at the ff/rr sensors, bare some copper wire shaping into a ů and plug into the connector. If the red lights are on your wiring is good.from reading i figured i'd pull the wires at the front locker and give them a look and test. after sometime of having the car on (key on, engine off) and the f/r lockers set to 'on' i was able to pull the plugs and test them, I am getting no reading out of the two plugs.
also, forgot to mention all fuses look ok.
i'll try to trace back the wires and find the connections on the other end.
was my test appropriate or do i need to check those wires when the engine is running or at the same time the f/r locker switch is activated?
