What does that PS pump mount look like?It’s the 1974 with the locked 60 axles SOA
It’s the “first” one.
Crap?What does that PS pump mount look like?
This is their first ToyotaI guess they can afford a new shop with all the work you're giving them.
Ahh, so different shop than the other picsThis is their first Toyota
Tying up…er, supporting several shops simultaneouslyAhh, so different shop than the other pics
"First Pig" -> Good name for this one! It all started here...It’s the 1974 with the locked 60 axles SOA
Oh boy...
I bought another one (full set) years ago from SOR.Oh boy...
What is the plan for clean up and repair on this harness?
June: shakedown and PP22
Good luck! Hopefully you can keep closer to your schedule than me.Outside and jams almost done. Should have the roof done by weeks end.
Rough schedule:
January: get it all sanded, on the rotisserie, sandblasted, set in epoxy primer, start on metal work.
February: get all the metal work done, rust repaired, set in high build primer, put the vehicle back together for fitment, fix all needed areas and gaps,disassemble metal panels.
March: install 1hz, h55f, splitcsse, fabricate all needed for the trans hump, fabricate dash area, start body work, block sand, undercoat (lizzard skin) inside floor and underside, seal and paint inside and jams, then mask and paint outside.
April: color sand and polish, start reassembly, install dash, all electrical. Adjust body panels, install glass and interior.
May: finish all detail work and deliver by months end.
It is one, two or three, definitely not four, five or six they all got shipped out of the country...... Or did they?Which one is this?? Confused!!!
