I read a few older threads and got a lot of mixed information from them. Can anyone give me a straight answer on what type of fluid is okay for a 99 Land cruiser? Is it okay to just use the mobile one synthetic ATF?
Thanks!
Oh my.. Here's it comes.. M1 Syn ATF is fine. I think there are many on here using it. A 99 model is easy since it only requires Dexron III.
So anything from Costco or Walmart (e.g. from Warren) to the most expensive boutique Dexron compatible on this earth.
What are your other vehicles? Are you using an ATF that you like today?
I'm pulling my hair out!! T-IV or Dexron ATF?
I've done TONS of searching on this, only to have completely different answers; I'm really getting frustrated :bang: I bought some Mobil 1 synthetic ATF today, called them, they said I could use it with my truck. They said it complies both with Dexron and T-IV ?? Not sure how this can be, but...forum.ih8mud.com
In that case, you have many options for a Dex III+ compatible. I change fluids more often than most due to extreme dust and mud conditions.I have a 2013 Mazda 3 that has supposed lifetime fluid, Im getting ready to do that soon. Have a few more years until my F250 will need any ATF.
98-02 158-176F. Dex III ATF |
2003 158-176F Toy IV |
2004-up 98-115f Toy WS ATF (TSB set level 04-07) |
M1 MV full syn ATF is top shelf.
Our 98-02 love it. My local Toyota Dealerships shop Uses it in problem Transmission running hot, to get temp down. Otherwise they just use cheap bulk Dex III.
BTW: All 98 thur 2022 LC and LX power steering love it too. For that matter any Toyota requiring ATF dex I, II or III
I've done full 12qt flushes in 98 w/ ~350K miles that had never been flushed before, but used for towing. Trans was slipping, but no longer after. My 00LX w/350K miles also. My 01 I ran it in last 100K miles I had it. Had a 01LX last summer a CA shop did drain and fill with who knows what. Throwing codes and runn hot. Flushed w/full 12 qt M1 and no more issue. I flushed more Dex III rated transmission with M1, than I can remember. Not one has had a problem. They range for 60K to 370K miles before first flush. Improved each and everyone's shifting. Fact is you can barely feel when they shift.
Difficult part is setting level. As it's hard to get to hot:
98-02 158-176F. Dex III ATF 2003 158-176F Toy IV 2004-up 98-115f Toy WS ATF (TSB set level 04-07)
If Exxonmobil would approve for 03 which takes Toy IV, I'd use it in them. I'd use in place of Toy WS ATF, if approved.
BTW: Exxonmobil makes transmission fluid for Toyota. They also make a full syn WS, but will not sell in USA. Wonder why!
I wish our Walmarts would sell it. Stuff is not cheap, but well worth it.
Many will warn, do not do a full 12qt flush.Thanks for the info! My 99 has 245k and I don't know if the trans is ever been serviced. I plan to do a 12 qt flush myself as part of the baseline.
I was planning on swapping my fluid with valvoline max life Dexron III/Mercon. I've heard from others that have used it on 100's. Mine is an '02, I believe it would be a fine choice?
Interesting. I just realized there is the Mobil MV ATF (blue bottle, red cap) and Mobil 1 synthetic ATF (grey bottle). Mobil 1 Synthetic ATF is what I ordered earlier today. Should I cancel the order and order the Mobil MV ATF? On the product pages linked, it shows MV works with toyota type D-III, is that different than the GM DEXRON IIIH mentioned in the Mobil 1 Synethic ATF product page? Am I just overthinking this or do you think it matters?I've just spent some time on the phone with Exxonmobil engineer tech support. Basically they can't give much info on the Toyota products they make.
Gist of conversation:
The Mobile One line, is flag ship and top shelve. For our possposes, Mobile One MV full synthetic, is approved for use as Dexron III. Which is what's called for in our: 98-02 transmission and 98-up Power steering
Mobil MV full syn ATF, is a very high quality, but not as high base stock as Mobil ONE. Both very high quality. But the ONE, has better heat resistance and longer life rating. Not something most would every notice. Mobil MV Full syn ATF is approved for (not tested with or approved by Toyota) where Dexron III and Toy IV and Toy WS is called for. So can be use 98-up transmission & power steering. This product was a blended product, reformulated in the last to a full Synthetic. I've got to give it a try one day for sure. I see as a step up above Toyota IV or WS as it's a full synthetic.
When I compare prices. If price does tell anything other than marketing.
Mobil One is top shelf.
Mobil, is on second shelf.
Toyota (made by Exxonmobil) third shelf down, of the three. But still very high quality.
Consider also Toyota mark-ups. Cost difference would put Mobil One in a super category, over Toyota.
Ddi you drain all ~4.5 gallons at once? Or did you flush and fill over time? I thought I read on mud somewhere that opening the drain plug typically allows 4-6 quarts to come out, then you can fill that amount, run the truck to let it cycle for 1K miles, then flush another 4-6 quarts out and fill again... I guess to slowly clean out all used fluid out of all trans components. Maybe I read something wrong but just curious.I just did the flush on my 02 yesterday with the Valvoline Max Life - $17.95 per Gal / Amazon. I flushed and refilled with roughly 17 quarts.
I have also used this over and over again on my 02 4runner (301K). never an issue.
