Hello All- Apparently I’ve hit the wall on steering box (“gear” as the manual calls it)…. Have big-time leak with a pool of gear oil trickling down from the body and leaf-springs below. Steering works fine without excessive play or any grinding. Haynes manual talks to this being a non-overhaul part without special tools. I’m thinking a seal kit would be all it needs. When I say seal kit, I mean gasket to go around inspection plate on back and shaft two shaft seals. Is my thinking accurate or do I need to fully disassemble for shaft seals and therefore buy a replacement box?
Thx,
Rick
Thx,
Rick
