- Thread starter
- #981
When I had the radiator in last I did a test fit of both hoses to check routing and clearance. I found the bottom hose was a squeeze past the inner fender.. so I cut it out to get a bit more room.
I also removed some divot type depression where I need to mount the hard brake lines between the firewall and the chassis..
put a lip on all my inner fender mods to give it a bit more strength.
Heres where the brake and cluch run down to meet soft lines on the clutch slave, and brake union blocks on the chassis.
An fed the vac line that runs across the firewall behind the brake booster and attached it to a captured nut:
