Does anyone know the ON/OFF temperatures for an 82’ FJ40 carburetor cooling fan?
I think it works on time, not temp.
Thanks all for responding; however I was looking for the turn-on temperature (high temp.) that the fan comes on at.
Thanks a lot for the infoThe sensor doesn't actually touch anything, but senses air temperature near the base of the carb. As noted in this photo that I posted previously, it's mounted to an "L" bracket hanging off the intake manifold.
Do you know how far the tip of the sensor from the intake manifold or exhaust manifold? I'm trying to make it as close as possible to the oem solution....thanksThe sensor doesn't actually touch anything, but senses air temperature near the base of the carb. As noted in this photo that I posted previously, it's mounted to an "L" bracket hanging off the intake manifold.
I happen to have this one on my desk at my office.Do you know how far the tip of the sensor from the intake manifold or exhaust manifold? I'm trying to make it as close as possible to the oem solution....thanks
Great info. ThanksIt's about 1/2 inch aft of the intake manifold and 1/2 inch outboard of the exhaust manifold.
What a coincidence.... thanks for the pic. BTW- is it a normal water/air temperature sensor?
