Good to know, thank you!I had to use 1/2" spacers. Got these off Amazon.
Amazon product ASIN B00390RLLY
The bolts the spacers come with are s***, get grade 8 from ACE instead. Also had to buy the offset hawse from Slee.
I have been out of the mountain bike game for a really long time. What frame is that? The headtube angle looks incredibly slack.
Yep, Hartman Rocks.Heartmens rocks?
I doubt a fender flare would really solve the problem. I bet real automotive seam sealer would do the trick though. At least for a good 10-15 years.
@Blk80inAZ Ive been wrong before and I might be wrong again, but my belt is routed differently. . . and these other ones that I google searched.
Hate to break it to you, but there is, and it’s a breeze to install. 1 minute max. Your’s looks good though.Installed a new antenna, this was a pain. First, there is no adapter for screwing something into the stock unit. Don’t believe ebay.
It wasn’t that hard to get the stock unit out. Take off the top nut with a needle nose and then there’s a bolt in the engine bay that holds the unit in place.
After that it gets difficult. The antenna cable does not come off the stock antenna easily and you can’t plug it into the new antenna.
You can’t just pull the new antenna wire through off the old one as it doesn’t budge. I started taking off the fender to run it through the stock hole but gave up and just ran it through the plug with the engine harness.
WTF .........mine has always been routed this way. Now I must try to reroute the belt and see if everything fits . It’s like finding out you’ve been wearing your underwear backwards your entire life and nobody ever said anything.....@Blk80inAZ Ive been wrong before and I might be wrong again, but my belt is routed differently. . . and these other ones that I google searched.
View attachment 2648513View attachment 2648514View attachment 2648515View attachment 2648516
Lots of people had the white writing out during the 60s and 70s and I am old enough to remember that too!It’s super 1980’s and 90’s. I am old enough to remember.
People rehash styles. I noticed the mullet is making a comeback down in Australia.
Cheers
The problem I have now is the fact that there is already a giant bead of cracked liquid nails inside the quarter panels and I have no idea how to get it out.
And coming from the outside I have the bed liner and a 1/4" gap between the two pieces to deal with.
I think I am just going to bite the bullet, grind off the liner, and try to weld the two pieces together.
Or maybe just do a body swap.....
I would still like someone else to weigh in. Just cuz it's on the internet, doesn't mean I'm right. Maybe yours is right and we are all wrongWTF .........mine has always been routed this way. Now I must try to reroute the belt and see if everything fits . It’s like finding out you’ve been wearing your underwear backwards your entire life and nobody ever said anything.....
Do you have a link to that?Hate to break it to you, but there is, and it’s a breeze to install. 1 minute max. Your’s looks good though.
Thank. Just wanted another opinion because I don't want to say something wrong. And yes, Joey does sell these and have in stock.Factory sticker (just noticed is on its last leg)
Think Joey might be making these as well? Or just carb cert stickers perhaps Flat pulley is the tensioner.
View attachment 2648726View attachment 2648727View attachment 2648728
