#6 White to brown bodywork and paint (Tatonka) (3 Viewers)
Rust in the door jamb seam, bubbling from under the seam sealer.
Gas door opening is caved in from a previous accident. I can’t get it to stay after I stretch it out from the inside, so I’m making a bracket to hold it. I will attach it to the inside.
What brand filler do you use?
Shop brand called Vitech. It’s my favorite. I’m sure it’s made by someone else though, probably something high-end like Rage Gold or something.
What gauge sheet metal do you use for patch work?
This one had Ben rust proofed previously. The stuff did a fine job in the rockers. It’s a wax type spray in goop, and it was still packed in the corner, and still soft and sticky. I will clean this up and weld it back on. The other side shows signs of rust, so it might be a different story.
