93yotasr5
Come and take it
Congrats! It’s such a good feeling when it’s all buttoned back up and there is no more leak on the floorboards! Such a pain in the ass job though! I know now why it costs so much to have a shop do the work.
Magnetic sheet placed over top of the sunroof. (Stuff people slap on the door of their truck with company logo)Can you please elaborate on this some more?
That moonroof is made of glass, how is a mag sheet sticking to it and what's the purpose?Magnetic sheet placed over top of the sunroof. (Stuff people slap on the door of their truck with company logo)
Prevents water ingress due to dried up/shrunk seals. It’s sticking to the metal around the sunroof. I’ve not done this or seen in person.That moonroof is made of glass, how is a mag sheet sticking to it and what's the purpose?
Will it start from neutral?Went to start the truck again after I went for a ride and nothing.
Everything comes on, but the starter dont even click. Battery still showing good voltage. I ordered a couple of fusible links just for peace of mind, but since the CEL comes on with the key in ACC, I dont think this is the problem.
Any suggestions where to start?
I’ve thought that would be the case too, but no.Will it start from neutral?
What? You don't have glass magnets?That moonroof is made of glass, how is a mag sheet sticking to it and what's the purpose?
You buffed your weiner?i parked mine next to an absolute legend. this a few months ago though, but it was a weekend.. then i buffed it, real real nice.
Untitled by bill bill2, on Flickr
I was able to find a 60” x24” piece for about half that cost on Amazon warehouse deals. otherwise my cut dims, and radius corners sound pretty darn close to yours. I didn’t do any taping/gluing on the leading edges since I’ve got the prinsu air dam on the rack.Total cost or the 10 ft sheet was about $60 on Amazon and was the same supplier
Yeah. Dead simple idea! Will snap some more pics, but was sorta waiting for the rain test later this week to see how it really performs. It’s a great California solution as it stops raining here like May through October...just peel it off for the summer and slap it back on in the winter.Prevents water ingress due to dried up/shrunk seals. It’s sticking to the metal around the sunroof. I’ve not done this or seen in person.
Try checking the ignition wire connector on the starter body. I thought my starter was bad because I had those symptoms but it turned out that connector was just dirty inside. Cleaned it out and truck cranked immediately. No problems since and that was months ago.I’ve thought that would be the case too, but no.
Either in P or N the start will not even click
I'll try that once I get back home!Try checking the ignition wire connector on the starter body. I thought my starter was bad because I had those symptoms but it turned out that connector was just dirty inside. Cleaned it out and truck cranked immediately. No problems since and that was months ago.
You may have to wiggle it a bit while someone turns the key. But the main thing is making sure the connection is good. I too ordered and starter and then returned it.I'll try that once I get back home!
I have a Denso reman on the way just in case, but I can always return it!
Thanks!
This was something that plagued me after mine sat for only 2 weeks. Somehow the positive connection on the battery was a tiny bit loose (no clue how that happens from sitting). Tightned it back up and fired off without a hitch.Went to start the truck again after I went for a ride and nothing.
Из какой машины этот пластиковый солнцезащитный козырек, братан?[ATTACH = полный] 2563866 [/ ATTACH]
Bulgarian has a word for "Bro?"братан
