By the way here is a pic of the oversized Caps regardless of LED light brand they fit perfectly, installed the Hikari and no problem at all with AFS
Doesn't the plastic cap burn the leds out since the fan can't keep the led cool?By the way here is a pic of the oversized Caps regardless of LED light brand they fit perfectly, installed the Hikari and no problem at all with AFS
I've noticed that happen with other cars
Can anyone with an lx570 of the 2009-ish era comment if these CougarMotor LEDs worked out well for you? As noted the eyes of Hikari Eyes of Megatron aren’t available new anymore from Amazon and a bit skeptical of buying them used for more money than a month or two back when I put them in my cart....Buy the CougarMotor version from Amazon. I started using them quite a few years ago, and none of the cars I put them on have failed yet. Also stupidly bright! I'm actually replacing my LED low beams with HID in hopes of not being so blinding.
CougarMotor LEDs
From the first post in this thread:Just did all Cougar's last night on our '11 LX. I'm not a headlight geek, so bright is relative. They are certainly brighter than the halogens that came out though. No AFS issues either. Bonus, Amazon has a sale on them right now for $29.99 a piece.
High Beams
Lows and Fogs
Anyone know what bulb is half lit in the high beam lens up in the corner? Didn't get a chance to pull it out and check last night. Will eventually try to replace it with an LED as well.
194, T10, W5W “Wedge” Bulb Parking Light
Oh duh, I guess I thought that referred to the side marker lights or something. Just put these guys in. Real nice and bright.(As well as interior lights)
I ordered a part of new headlights from China, it should arrive these days.View attachment 2596818
This headlight works for 2008-2015, I will install them on Monday. And the link @grinchy shared looks like same with mine. I order them from Ali express Chinese edition. The seller told me that DRL will work without any other line in fuse box.Are these for pre-2016? Can you share a link?
sweet. can you take a pic of the piece you had to cut off to fit?
