My fj60 wont come up to operating temp unless I am idling, Once I start to move/drive then goes down to the edge of the white line in the gauge or just into the white area. The problem started last year when I had the radiator replaced, and the fan clutch checked as well for a overheating issue at idle. After getting it out of the shop It seems to warm up a little bit more on long hwy drives. This is good in 85-95 deg weather down here in South FL. For the past two days in the morning the heaters (front and rear) were blowing warm, not hot, even after a 7-8 min warm up in the driveway and 10 min drive. Down here in south FL the heater is rarely used. Periodically throughout the year I randomly turn on my heaters just to circulate the coolant through the heater coarse and its hot enough to cook an egg, but that's when the outside temp is 90 deg not 50 degs
What does this sound like to you guys, I was thinking it might be an incorrectly installed t-stat?
I wanted some other input from some other people first before I open up the cooling system to replace the t-stat. Any other Ideas?
