- Location
- United States
Hey fellas,
I am interested in putting my 2002 LX470 up for sale, but have no clue where to start from a valuation perspective.
Here is a list of some major things:
330k miles
6/2/19 -steprail delete
10/10/19 replace rear passenger AHC hose that had a seeping leak
11/2019-Added tow package and 4 pin connector
11/2019- New exhaust
12/18/19-Timing belt, water pump, thermostat, hydraulic tensioner, tensioner pulley, idler pulley, tensioner bearing, idler bearing, serpentine belt, fan bracket, upper/lower radiator hoses, Toyota red fluid, heater T's, radiator cap.
12/2019- Synthetic oil change. Valvoline Syntec.
Roof rack added May 2020.
Took out carpet and detail cleaned May 2020.
1/12/20- new Ridies front leather with armrest and center console.
1/15/20- added floormats
6/8/20- Changed in cabin air filters and Mobil1 Synthetic oil change
6/6/20- Kilmatz entire floor and walls.
6/12/20- Nav-Delete to LC controls
6/12/20 - installed new head unit with navigation, backup camera, new Hertz door speakers,, Skar sub and JL amp under passenger seat, new antenna, LED bright headlight conversion, LED interior lights
11/7/20. tyranny flush and refill, mostly new suspension bushings, front/center/rear diff drain/refill, replaced rear pinion seal.
11/20/20- Mobil1 Synthetic oil change
Currently has a rusty upper liftgate. Just painted a new one and going to install this weekend.
Most of this done within the 12 months or so and less than 8k miles.
The bad....little rust underneath because it was a northern vehicle, no rot. Has a tick when warming up and goes away after 2-3 mins. I have no clue what that is. Scuff and minor dent on front passenger corner, infamous clunk even after lubing driveshafts. Cannot shift it into 4LO. It is seized up. I bought it from the original owner and she said she never put it in 4WD. I have all of her service records from Lexus.
Probably forgetting a lot. Of course, it is all put back together on the interior and 2nd row has typical "crack" appearance but nothing torn. 3rd row is great.
Any guidance on a starting price?
330k miles
