The fridge will cycle less when packed full of food/beer. I'm not sure how much less, but it'll extend your run time by quite a bit I'd imagine.
Nice work
Nice work
Brothers from different mothers!Thought I would sneak out to the shop and put some weather strip I've had for my doors since 2014 in-between prepping my house for paint.
I got the drivers door wrapped up and shut the door to check things out and the lower window channel fell out, my body guy was supposed to weld some cracking on the new door I bought and he decided spot putty was better than welding.
One more thing I need to do before the pig party now.
I was able to test the LiFePO4 battery box I made a little yesterday and came up with a plan on how to interface it with my current wiring and hopefully keep the electrical fires to a minimum...
LiFePO4 batteries are the answer to this problem but they need some special considerations on the front side to get all they have to offer, I’m learning as I go so this is an ever changing plan so I first bought a Renogy DCC12 series battery charger (generic 20 amp DC/DC charger) thinking it would help me limit the current to my existing system to something around 20AMPS, in theory I suppose this would have worked but in practice it doesn’t. With the total length of 10gauge wire I tied into I was getting a voltage drop and I was seeing amperage spikes up around 40 AMPS, the DC/DC charger tries to maintain 14.3 volts at 20 AMPS output and will spike the input AMPS when the input voltage drops. My only option if I wanted to keep potential trail issues to a minimum was upgrade the wire size to #8. This is my fifth or sixth attempt to lower the voltage drop and I’m a little pressed for time now and needed to just get something usable for the upcoming camping trip so this is where I’m at now.
Sorry for all the rambling about nothing but I know a few of you guys are in the planning stage of your builds still and I would strongly encourage you to upsize a circuit running to your rear compartment even if you don’t think you’ll ever need it today, I thought 10 gauge was more than enough 4 year ago.
Yeah I'm going to have to put some thought into a permanent solution, sitting around a camp fire with a few smart guys like you having adult beverages is going to go a long way to speeding up my learning curve.
Put your batteries in the center of the truck and all your wire runs are shorter
Actually considering doing this - perfect place to put a battery box under the back seat.
But anyways... very interested in what you come up with here Mack. BTW, were you thinking about using a solar panel at all while the engine is not running?
LiFePO4 batteries the way I’m buying them are almost perfect for mounting them in available spaces in the cab of a 55 or a 60 in Johnny’s case, you need 4 cells (Nominal Voltage: 3.2v per cell) and can configure them to lay flat @ about 1.5” tall if you were mounting them under a seat.
This is the specifications for the 100ah cell that Johnny used:
Minimum Capacity: 100ah
End-of-charge Voltage: 3.65v per cell
End-of-discharge Voltage: 2.2v per cell
Max Continuous Discharge current: 200A (2C)
Max Discharge Surge: 500A under 5 seconds
Standard Charge current: 50A (0.5C)
Max Charge current surge: 100A (1C) under 10 seconds
Charging Temperature: 0 to 50℃
Discharging Temperature: -10 to 50℃
Dimensions: Height 11.5″, Width 5.25″, Thickness 1.5″
Weight: 5.85lb per cell
So as you can see a small lightweight battery with a true 100ah capacity that easily tucks into an available space is going to be about perfect for a second battery in a camping rig.
Solar would also be cool if you plan on base camping for a day or two at a time with your rig, like I keep saying about our hobby there really isn’t a wrong answer if we are all out here in our garage having fun building our vision of the perfect pig.
First thing to remember here Bob “I’m a janitor” I get paid to clean up other people’s messes not design battery systems so take all of my opinions with a grain of salt.
My ideal system would keep the “start” battery in the factory location and let it continue in its role as the “start” battery and add a LiFePO4 battery second battery to run everything else, these two batteries can be combined with something like the power gate battery isolator like Scraps and I use if needed when one runs too low to do what you need. This would not only be easier offering more mounting options but offer 4X the capacity (the only reason to add a second battery in the first place) at ¼ the weight of our standard Pig sized batteries. (About 30 usable amp hour)
It’s my understanding most of the LiFePO4 batteries “lithium” over promise on capacities when new and start to level into advertised capacities as they age.
Pablo,I come bearing questions
Pablo,
You are mostly correct with most of you assumptions unfortunately I do not have the time to type out the reply you deserve, painting my house right now ontop of all the other junk I'm in the middle of trying to get ready for PP20.
If you were going to make the party then yes this would make for some great campfire conversation, I will do my best to remember to give you a proper reply with links sometime after I get back
I swear I did some reading before showing up with questions, so against my better judgement I am trying to multi-quote what I think are relevant points.
In the spirit of "knowing just enough to be dangerous", I come bearing questions and very little in the way of contributions...
Wondering more about how to interface the battery box w/ your current wiring. I don't remember, but I think you were running an AGM as your primary battery. My limited understanding is that trying blend different types of batteries sets up quite a challenge in terms of charging and battery management. I am curious what logic you will arrive at for charging when the engine is running and isolating the batteries...
Is the Renogy just for charging the LiFePO4 battery pack? Or is it a "gate" that manages input and output?
When you talk about limiting the current to your existing system to 20A, are you talking about output from the Li pack?
Perfect place for them!
Are you thinking of inside the people compartment? I saw @J Mack mention battery packs that were 1.5" tall, that should fit under the factory seat, and I think even work if you fold the seat down. Not sure if the LiFePO4 packs need any cooling when they charge. Cool that there is no hydrogen gas discharge to worry about!
I was also thinking about solar panels! They are getting cheaper and flexible, I bet @J Mack has enough clearance under his rack he could affix a panel to the roof. Then just find the best place to route the wiring down from the panel. Back to my earlier questions about managing the charging system for different types of batteries...
1.5" is pretty sweet! Do they need to be in the hard case system you built? Or was that to integrate the charger? Being able to organize an array under the rear seat would be pretty nice...
As for solar, back to my questions of logic for the isolator and charging the different batteries...
Holy cow! Johnny C. tech FTW!
And hit a home run, thank you Johnny!I can try.
Camp fires are for BS where I come from, tech talk for sober daysAnd hit a home run, thank you Johnny!
Great little write-up there @GLTHFJ60 , thanks for taking the time to roll that up into something we can chew on. There’s another point I for one would appreciate you expanding on -
That sweet ammo-can center console!
Clog away!!Don't need to clog up Jim's thread any further
Not a big deal.
