Tomorrow I shall reconnect the manifold gauges to check the pressures....what should they be ?
Depends on the ambient temperature (outside air temp). Correct pressure will increase with the temperature). But a good rule of thumb for say 85°F-90°F ambient would be 30-35 psi on the low side and 200-225 psi on the high side.
I'm thinking that I using the wrong repair manual if it says 1000g +/- 50g when it should be 750-800 (28oz)
For a vehicle without Rear Air....I would be much surprised if 1000g were not an overcharge.
Im afraid I dont under the cold and hot lines ...shouldnt they always be cold given it full of refrigerant ?
No. Your high side line (and condenser) will be hot. Your low side line (and evaporator) will be cool/cold.
Expand for replies
