- Location
- United States
This is a list of parts I have left from partout. If not on the list, I do not have.
Pricing is definitely negotiable . Will ship. Just make me an offer.
Finally disassembled my doors and rear hatch. No interior panels.
$20 each Door glass windows and quarter (has tint)
$5 each Door glass run channel
$15 each Door weatherstripping (plastic clips still attached)
$35 each Power latch lock actuator assemply
$35 each Power window Actuator (front pass sold)
$20 each Exterior door handles maroon
$15 each Interior door handles tan brown
$5 each set Door hinges
$15 each Door wiring harness
$25 Door control ecu 85980-60110
$40 Rear hatch window wiper actuator . Control mod . wiper
$20 Hood - maroon (some rust)
$60 Sunroof assemby
$20 Dash and rear vent ducts AC
$50 each shell only Doors (some rust)
$20 Carpet
$20 Cooling fan & clutch
$15 ABS skid computer 89540-60040
$60 each Air bag assembly and cover
$15 Gas door release cable
$15 Exhaust manifold covers 11212-66011
$15 Motor and trans mounts
$175 Dash wiring harness 82131-6A432
$13 Roof control 85921-60011
$145 Harmonic balancer damper w/ bolt
$12 Headlamp retainer 85961-300526
$12 Seatbelt warning module 85991-16050
$90 Fuse wiring harness
$12 Bumper lower grill 53112-60030
$75 Floor wire 82161-60033
$60 AC evaporator assembly 445800-0930
$10 Relay denso 90987-02004
$55 Sunroof motor 85730-60011
$10 Flasher 81980-12070
$10 Relay 056700-4750
$50 Floor wire 82162-60052
$10 Heater amp module 87161-60020
$10 Fuel tank filler neck shield boot
$50 Actuator assembly brake - for parts only 44510-60010
$30 Fuel pump relay 28381-16020
$10 ABS relay skid control 88263-12080
$30 Igniter 89621-26010
$10 motor mounts
$30 Cruise control 88240-60060
$30 Floor wire 82181-60043
$30 Gas pedal assembly and cable
$10 Hub kit
$20 Transmission relay 89531-60010
$10 rear heat control
$20 Lamp control 85965-60010
$10 Rear defrost control
$10 relay denso 90987-01003
$10 Radio antenna control
$5 door sensors
$5 Relay denso 90987-04002
$5 relay denso 90987-02006
$5 Lower water neck
$5 RH passenger rear bumber mount
$5 Door latch hardware
$5 front hub-dust seal
$5 Cam shaft seal
$5 engine rear oil seal
$5 Gasket differential 42181-60060
$5 passenger door lock switch
$5 power outlet trim
$60 Sunroof assemby
$20 Carpet
$10 motor mounts
$10 Hub kit
$5 door sensors
$5 Lower water neck
$5 Cam shaft seal
