I cut those tapers so no matter which way i installed it under the front drivers side axle tube it would clear those 2 welded on brackets. Plus by machining off the front of the adapter with that taper, it allows the adapter contact area with the underside of the drivers side axle tube to be just a little bit wider.Nice why the offset legs?
