RedHeadedStepChild
Proudly wearing my MC1R mutation!
I hope you didn’t have to hold it the whole time.I have saved up a bunch of little plastic bowls, about 5-6" diameter and maybe 3" deep. Mostly from take out etc. EVERY time I remove even one bolt it goes in a bowl, period. If it is going to be a while before re install it then gets bagged and tagged.
I've lost sleep for the same reason Del and it'll drive you nuts.
Installed a new toilet. I made sure I had all I needed, wax ring, curb bolts, toilet supply line @16". It's a tall toilet and I measured it at the store for supply line. Install the thing only to find that the valve at the floor has a 1/2" compression instead of a 3/8" compression. DAMN. It's an under sink valve. Off to Chesnee hardware I go with the old hose in hand. No luck. I did get an adapter from the valve so i could get it operational until I get the proper hose. No luck.
Off to Lowes in Boiling Springs, found one in 12" , not long enough. Guy working there tells me they don't have hoses like that. I show him the one in my hand that I found on the shelf. Again he tells me they do not have those hoses. The old man, retired plumber that was helping me out tells the guy we just found it right there, pointing. Again "we do not have those hoses. Old guy says "please go away young man" to the Lowes guy.
Off to Home Depot in Spartanburg. They have what I need, lots of them in 12" and 20", no 16". So I settled for the 20". Two and and a half hours later I arrive home and 5 minutes later job is done.
Guy at Chesnee hardware told me, "It's plumbing Stan, requires at least three trips before you are done" He's a profit for sure
