- Location
- United States
A few parts from my stockpile, all are original to the vehicle with the exception of the distributor cap and the alternator shows Toyo reman. All were in working condition at time of removal, with ~ 203k on the rig.
All prices OBO and include CONUS shipping.
Wiring Harness - $125
* A couple broken tabs/connectors, the most visible was the one at the distributor. I safety wired it in place and it worked fine.
Distributor - $100
* Aftermarket cap, faded sticker shows OEM.
Alternator - $50
* remanufactured Toyota. Unknown install date.
Power Steering Pump - $80
* appears to be original/OEM; leaking at time of removal, I opted to replace vs rebuild due to poor skills...
Coolant Overflow Reservoir - $40
* Minor plastic fading on top near overflow downspout; cap seals well
Washer Fluid Reservoir - $30
* Heavy plastic pitting on top but does not leak. Includes motor grommet and plastic filter under cap.
Front Seat Headrest Covers - $30
* Normal for age, so significant rips/tears
EGR Valve/Pipe - $30
* I was throwing a P0401 code like everyone else, unknown if the valve works properly.
Differential Breather Box & Frame Mount - $20
* I did the breather extension to the engine bay and removed these parts
Distributor - $100
Alternator - $50
