- Joined
- Sep 9, 2004
- Threads
- 186
- Messages
- 11,031
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #641
Mounted.
Cheers
Cheers
Are these tools specific to the IP that they are used on?? I ask this because the lever pivot does not seem to be in the middle, which would amplify the movement (reading) on the guage side?? Or does it pivot in the middle. Sorry if this is a dumb question, but i once made a fitting to get the guage directly in the IP of a 3BII ( rotary pump), and I never got it right. The right tool may have solved the problem!!
Would this clutch be similar to a HZ76?? If so where the heck do you adjust it. Mine just has a positive pressure on the thrust bearing, therefor pressure plate, caused by a spring with in the slave cylinder. Took me a while to get used to this as I am used to old systems which use springs to keep the thrust bearing AWAY from the pressure plate.
