Thank you. Just ordered tank.
Glad you found the info useful. I stumbled across it and wish it had been more common knowledge.
That's where I'll be installing the early '90s Toyota Celica clock I'll be getting in the mail tomorrow. I already have a harness made up.
My '71 FJ40 build will be a resto-mod, with many changes from stock, but all Toyota parts where available. So the Celica clock would be OK.
I've got another non-Land Cruiser Toyota part coming in the mail today, a Supra throttle body bell crank assembly I'll adapt for my carburetor linkage. The way the '71 is set up the throttle cable will interfere with the '76 air cleaner I'll be using. I'll mimic the '73 FJ40 set-up, which is unique to the '73 model year - it's hard to find those kinds of parts. It's coming all the way from Akron, OH .This resto would have been done a long time ago if we weren’t shackled by stock appearance.
@Xylonmedia You might have coolant getting in the combustion chamber?
How long did it take you to get the paint off of all the parts shown? And what set-up did you use? I'll be doing the same for my '71 FJ40 build, including the fairly clean 3/4 tub I bought in Northern California earlier this year. I was thinking of taking all the parts to my place in Nevada, where the tub is now, and getting everything done at once. I have an 80-gallon 175 psi two-stage compressor and a Craftsman nozzle and hose set-up, but it seems slow. Any tips or hints on equipment or technique would be appreciated. BTW, I'll be doing the blasting outdoors on my 3/4 acre desert lot, so if I use sand I don't have to worry about where it ends up, unless I want to recycle it.Finally got around to peeling the paint of the STPCHLD. I proved what I was guessing. An amazing surviving FJ40 with the only problems being what previous owners did to the truck. VERY little signs of any rust. Just look how incredibly clean the bottoms of the doors are!
View attachment 1933109View attachment 1933110View attachment 1933111
Drove it today, and split firewood View attachment 1933623
