Yes, but I was comparing a HP 8" to a LP 9.5" differential(but didn't mention that), and their strength in a front axle application. There is no doubt that that the 60 also has huge tubes, shafts, C's and knuckles, which a stock 44 does not.Funny. The internals and especially the inner shafts of HP30's and HP44's are tiny in comparison to a D60. Not to mention the huge aftermarket support and parts availability that @slow95z mentioned
Seems that after you put decent shafts in a HP44 the crackling sound of the R&P seems to follow, in similar situations as a HP 8". Yet you put a LP 60 or 9.5 in the front and the problem doesn't appear nearly as quickly. Trying to find a spot to compare apple(ish).
Don't forget D60 talk.How did the D30 and D44 talk get in here?
Because technical talk. HP D44 has close to a 8" RG, and a LP 60 has a 9.75" RG from what I recall? And we were comparing a HP 8" to a LP 9.5" Seems like a decent direction to compare R&P strengths.
I'm just trying to understand how a LP 9.5" is weaker than a HP 8" differential in a front axle application
