So I have a Potrtuguese spec (12V) BJ 73 with a Spanish 1HDT(?) Block number 0008023. Was told it was from a 93 HDJ80. Numbers seem awful low from what I have read here. I may not have prioritized properly but have been building from the bottom up mechanically. Front and rear axles, re gearing, lockers, suspension, etc., etc.. Now I am trying to turn my attention to the power plant and get it running right. Cold start is terrible and I'm talking only 30'F.
Checked glow plugs and they are toast, so they are on order. My plans are of course to eventually upgrade the turbo, run 3" exhaust and install an IC. Before I get into that too deep I was thinking I would swap in some new BEBs, service or replace injectors, run a compression test and change the oil. Not necessarily in that order. When looking for parts it seems it depends on the year of course and the block number seems as I stated very low for a 93. Then I read about the turbo HZ conversions. Then all the IPs I seem on the 1HDTs have a boost compensator which my IP does not??.
So what I need help with is:
1. How do I get the production date with just the block #?
2. Is this a 1HDt or HZT or Hybrid? I say hybrid because the top end looks to be 1HDT and don't know if heads are interchangeable.
3. Do have have the right IP or an adequate IP for upgrades? Seems I would need a boost compensator??
4. Will stock injectors suffice for my future upgrades?
4. What would be the most reasonable order to proceed with this project?
Thanks in advance for your wisdom and expertise!!!
