mongoose2231
Supporting Vendor
I have done a bunch of searching and FSM studying but want to pick your brains. I have a 1986 pickup and the brake lights stopped working. I have running lights and backup lights and turn signal lights, just not no brake lights. I have replaced the switch, since i realized the stop lights were out at work, 70 miles from home and its the first thing that came to mind. that still did not solve the problem. I now had some time to do some testing and of course, the fuse is good, switch is new, I have all other lights working, could it be a ground somewhere? Thew fsm points to a ground if everything else checks out. My question is where is the tail light switch ground located? Also, The voltmeter only reads about 6.5v at the switch. Is that the right voltage?
Any help is appreciated.
Thanks.
Thanks.
