Folks,
I was hoping to get some sage advice on a build for a (new to me) 2014 Land Cruiser 200 series. I may have to spread the build out over time so my wife doesn't divorce me but in the short term, I'd like to swap out wheels/tires (and possibly upgrade a suspension kit if needed).
As you guys know, the OEM stock wheel on the LC200 is 18x8, +60 offset, 5x150 lug pattern, 110.0 hub bore. And the OEM tire is 285/60r18. I'm ok with sticking to the OEM tire size if its too much trouble to upsize to 35" tires.
As much as I would like to push the wheels outward a bit more from the stock +60 offset, in doing so, I don't want to unintentionally mess up the suspension's geometry (for example, by creating too large of a “positive scrub radius”). I was thinking about the wheels below, but would appreciate this group’s collective thoughts on whether or not any of them would be a good fit for the LC200.
With aftermarket wheels, it has been nearly impossible to find a wheel that checks the boxes of each and every one of my following criteria: (1) hub centric, even if with adapters; (2) optimal offset that doesn’t throw off geometry & scrub radius in particular; and (3) load rating, whether indestructible forged, flow formed as a middle ground, or a cast wheel. Compromise is almost a necessity. I can usually check 1 of the boxes, and maybe 2 if I’m lucky, but never 3 – except that the Arctic Truck wheels seems to be spot on with everything, including a zero scrub radius.
With respect to offset, I’m less concerned about stuffing the wheel into the fender, because I’ve seen several folks in the forums that have stuff a zero offset wheel such as the TE37 (with OEM tire sizes) stuff the wheel at full compression/articulation. Instead, I was worried about the resulting effect of a large positive scrub radius on handling (e.g. creates toe out on acceleration, toe in during braking, additional stress/wear on bearings, lugs, suspension).
If I'm just overthinking the whole hub centric or offset thing, just let me know. I wasn't sure how important hub centric was for a heavy 5,800+ lb car, or whether a large positive scrub radius was anything to worry about.
On a side note, I'd like to eventually swap the front bumper for this Rhino Bar bumper on the Vogue Industries build, but its going to have to wait because my funds are finite.
Thank you in advance for your time. Look forward to the feedback from this group.
- 18" Volk TE37 Large PCD Progressive: 0 offset, not sure what hub bore is? Obi Wong Kenobi used to run these
- 18" Enkei RPT1: 0 offset. I saw this on RPM Offroad Groups's instagram and love this rim, but not sure if this is available in 5x150 lug pattern? ...or what the hub bore is?
- 18" Black Rhino Roku: +12 offset. One of the few aftermarket wheels that is hub centric to the LC200 with a 110.0 hub bore. 470SNC installed these on a GX, but they are also available for LC.
- 17" FN Koenig Six Shooter (unannounced): Smaller 17" diameter. +25 offset seems about just right. But not sure whether the hub bore is 110.0 for the LC200 or 110.5 for the 2014+ Tundra. According to Dustin at FN (who has been incredibly helpful), this has a 110.0 hub bore, but some of the pics I’ve seen also include installs on the 2014+ Tundra (which has hub bore that's 0.5mm larger than the LC200). As has been documented in other forums, Dustin is an upstanding guy and was completely candid in steering me away from the 18” FN BFD.
- 18" 2019 Tundra TRD Pro BBS forged: 18x8, +60 offset is same as existing OEM wheels so its not really really going to push the wheels out. 110.5 hub bore, which is 0.5mm larger than the LC200. codyaustin5 purchased a set recently, so hopefully we’ll get a chance to check them out on an LC200.
- 17" Arctic Truck brand: +30 offset. 110.0 hub bore. 10" wide. Smaller 17" diameter. Because this wheel is custom made for the LC200 only and no other car, it is a perfect fit, meaning its hub centric, and even though it pushes the offset outward by 30mm, it still maintains the same suspension geometry with a zero scrub radius. The Aussie Arctic truck build by Ballsbgym is nothing short of incredible. But as he indicated, Arctic Trucks won't export their wheels; instead they require customers to ship their trucks to Iceland to be converted. But he did mention that Fjallasport was willing to export the wheels. Also, while every single one of the Arctic Truck builds are stunning, they are all on 35" tires (or larger) - so its hard to visualize if the same wheel would look just as good on the OEM stock tire size. ...and would the OEM 285mm wide tire be too narrow to fit on a 10" wide wheel?
