My '92 had a lot of carbon in the intake and on the injectors after 300,000 miles and looked worse than yours. I cleaned everything up and replaced the seals and o-rings. I also replaced all the electrical connectors on the wiring harness since they were brittle and a couple of the locking tabs broke when taking them off.I am mostly worried about the shape the injectors are in.
how much carbon should be present on the injectors and in intake manifold open?
I took the connectors off the wiring harness from a 2001 4runner with 3.4L v-6.Do you have a link to those connectors? Mine needs a few...
Head gasket. I got a complete gasket set and replaced pretty much all seals and gaskets except rear main while I was at it. Everything I could get to without pulling the engine. No more leaks! I also replaced the oil pump since I had the pan off, but it didn't really need it. I could still see cross hatching in the cylinder walls and there was no discernible ring groove.Did you do a complete engine overhaul?
No
Yes
You do need a FSM, or
Factory Service Manual.
FSM?
No
Yes
