Hi all, I posted this forum a while back and the replies I got were pretty helpful so I figured I would try again .
I have been on a budget quest to drive my mom’s old 94 cruiser across the continent again. However, recently, I noticed my rear driver side disc brake was getting scarred by the pad.
When I was first getting the old girl running after a 10 year hiatus of sitting in the garage, I had found an old tech note from a garage saying that rear calipers had to be replaced. At that time, the calipers were not dragging and seemed to function properly.
Over the last several thousands of miles, the caliper seemed began to stick and cause the pad to become a sanding block for the rotor.
There were and are no leaks in the system, so I replaced both rear calipers, rotors, pads, and slide pins, and spending over an hour bleeding the system. I did forget to bleed to the LSV (probably the source?). The caliper at this point is brand new with new fluid and still dragging. All the other calipers work perfectly except this one. The brake pedal feels normal if not a little soft when the engine is turned on.
I’m going to be looking around the surrounding area this weekend to see if there is any rust keeping and parts from moving freely. At this point I’m not sure where to go from here, I just want my baby back on the road
