Hey guys,
So I've owned this truck for about 5 years. I've put around 75K miles on it. It has always ran warmer than I would like. When I first got it, the temp gauge needle would run above the second mark. It did not like to idle in hot traffic with the AC on. I never would hear the fan clutch kick in. We had a '98 4Runner so I know what the Toyota Roar is when the fan clutch kicks in. That first year I dove in, removed the fan, shroud and fan clutch. I split the shroud, replaced the fan clutch with an Aisan Unit with the red hub. I replaced all the belts with Mr. T belts and the idler pulley. At that point, I could tell someone had already been in here. Worm drive clamps and a non factory radiator was in there. Someone had also messed up the AC adjustment bolt. They actually turned in up side down so the only way to adjust the AC belt tension was to remove the PS pump and bracket. Not a fun time. I also replaced the thermostat with a 180 degree unit. SO it ran a little cooler. Sometimes under the second notch sometimes at it, still didn't like to idle in traffic and if I flogged in on the highway, it would heat up.
Hot at idle is fan clutch right? (just changed it) Hot on hwy is radiator right? (hadn't touched it)
The fluid looked terrible and rusty too. So I would have it flushed at shops, and I would flush it at home. It always looked dirty and brown crud would build up on the cap.
I felt like this was the week part of my rig. So I worked side jobs this summer and started stockpiling parts. I bought a Toyota thermostat, 190 degree, up and lower MR. T thermostat housing, new housing bolts from Mr. T and Mr. T gaskets. Mr T. water pump, Mr. T fan clutch, the red hub Aisan unit again (that will soon change) Mr. T fan, Mr. T belts, Hoses and clamps. Now for the radiator, I bought a Mishimoto aluminum 3 row radiator. I thought I was buying the best, but then read reviews on it mid way though tear down. Oh well, at least they honor their warranty.
So I dove in the week before my wife's bday. Hey, she told me to! (she wanted the stock pile of parts out of our closet)
I had never been this deep into this truck. I had done radiators and water pumps on my 40's but that just too easy.
The ARB bull bar sucked to work around, but it makes a nice close tool bench
I just loved the fact that I was going to have to loosen every damn accessory to get these belts off and to get to the water pump, not to mention they screwed up AC tensioner belt bolt.
I had a new bolt, with the special nut and acorn lock nut and a new AC tensioner pulley
