Upgraded my center diff switch to the real things
That sucks!
Now....turn it into a positive!
He dinged the:
bumper
hood
core support
grille
cowl
both front fenders.
That's good for at LEAST $3000. Throw some extra parts on it, slobber on some monstaliner, and buy some armor for the front!
You'll be money ahead in the long run!
@slow95z start looking for parts for a 93........
Pushed the core support back. Radiator is pushed a hair back. Hood obviously. And grill. Possibly lights as well.
Replaced all 4 u joints trying to fix my grrrr. Didn’t fix s***, but at 264k they needed replacing. I am thinking its my wheel bearings. With or without my front ds, i still get grrr’s, its just less pronounced.
At high speed on the highway (65~) in sweeping turns i get a vibration on either side. I checked by jacking up the truck, no play top to bottom or front to back, spin a wheel and it feels smooth, lock to lock is smooth. It almost feels like a motor mount but its only at high speeds, not rpm and my mounts look good.
Im lost. Whent weeling anyway, hit widowmaker at sycamore and had a hell of a time getting up, slick as snot! I was not alone as a bunch of other locked up jeeps struggled except one showoff with a 4cyl unlocked but at 10psi on tire just crawled up, but not the hardest chute. Finally made it up with 20 psi in the tires.
Yeah, better include a radiator in that too. I know you have the brass on in the 93.
My wife rear-ended a car a lot of years ago in our Jeep GC and it had "no damage" other than a slightly tweaked bumper. 9 months laterm the radiator started leaking on that side due to the hard flex it got. Too late for insurance to cover it.
Make sure you get "everything" covered.
I think in this case, if you would have had armor (ARB or equal) it may have caused more damage due to the height at which he hit.
Bummer.
Why no ARB?Sitting at a construction one way. ****er “forgot to put his brake on” and rolled back in to me. I had left room to get out but couldn’t make it so I sat and watched it happen. ****ing idiot!
Yep. Figuring radiator in there. Headlight tabs cracked so new lights. ****ing mess.
@LouisianaRubicon Yes it is. I didn't get the tank from Power Tank because in my area they don't fill the tanks, you just swap them out for full ones. I got mine at Airgas for ~$80 for the 10lb tank. Easily filled up all four 33" tires from 18psi to 38psi 10+ times and several other odd tires over the summer.
Some would have you believe it can’t be done, but I towed a full u-haul 6x12 with a 3F-E FJ80 on 35’s with stock gears about 1200 miles and averaged about 50mph!
But you made it!
sorry, suxSitting at a construction one way. ****er “forgot to put his brake on” and rolled back in to me. I had left room to get out but couldn’t make it so I sat and watched it happen. ****ing idiot!
OMG!!!!!!! Im not sure I would have kept it civil, hopefully you get a chack because WTF????Sitting at a construction one way. ****er “forgot to put his brake on” and rolled back in to me. I had left room to get out but couldn’t make it so I sat and watched it happen. ****ing idiot!
And Im gonna take a wild guess these will be avialable on LCP, yea??Upgraded my center diff switch to the real things
Why no ARB?
Oh....and did you stay back 300 feet?
Also, this is how much clearance my new garage door has, at least inside the garage it’s much taller!
