32cls6speedmt
Most Lexus dealerships are charging $130 per labor hour and higher for work. The fluid alone is around $100, and there is absolutely no way the tech will charge less than 1 hour of labor to perform a real complete flush of the system. The $330 quote sounds pretty spot on in my opinion. Don’t forget you will pay a minimum of $25 in shop supplies as well as sales tax on top of that. The stealership gets over $100 for an engine oil change, so you know $130 for AHC fluid change/flush is basically impossible!
The labor rate has sky rocketed. In our area Toyota is at $145 a hour. Lexus is $155.00. The fluids are very expensive. I have inquired about what fluid are they using at both dealerships to the service advisor but could not get an answer. I contacted a toyota dealership to price the differential and transfer case fluids. They stated we just use toyota gear oil which is 75/140 synthetic. List price of 21.10 per quart.
