Hopkins Plug-In Simple Vehicle Wiring Harness for Factory Tow Package - 7-Way and 4-Flat Connectors
This fit perfectly in my 05 -- I believe there is a different model for 03-04, but I am not 100% certain on the year cutover.
Wells has a moab area one too...Actually last time it was from the northern Colorado version. It’s buried on pg 76 now but this trail was from the original book. So far all the trails have been great. Also there’s a Moab/Utah book by the same author I’ve seen and another forum member in Utah mentioned as well. View attachment 1769663
it'll blow your mind when you get real tires and remove the running boards!!!View attachment 1769414 View attachment 1769415 Drove to Breckenridge. Tried to do another trail from the book. Peak 10. Turns out I’m staying on Village Rd where the trail starts. It goes to the top at 13,300, I was hoping to post that on the gettin high thread but I had to turn around at 10,600 feet. It just got too rutted and rocky and I’m bone stock with old street tires. There’s three trails within my reach still being stock. Going to Boreas Pass tomorrow and there’s another one in Alma, Kite Lake I think it’s called.
OH MY!!!
Installed hood blackout from Amaesing Decals, Outrider lower link mount skids, and BPS Leds[
those look beefey as foo! 3/16 steel?Are you going to weld the leading edge to the frame ??
I recall Total Chaos had some 3/16" steel ones as well. They didn't have the full boxed-in look and I think they just welded the back flap portion (angled end).
@Rock Taco: May I ask the reasoning with the UCA install? Im on the fence as to if I need to replace the UCAs with a med OME lift or not due to alignment.
Silly interior stuff but here is my Alphard steering wheel with a Lexus AB and SWC. My leather seat covers arrived...they go all the way back to the 3rd row. Looks soo much nicer than the 80's theme lookin' design on the OEM seats. (not sure if a GX option is offered but other than the arm rest on the front seat, should be the same??)
Where did you get the seat covers?? They look great! I'm sure you said already but I didn't see itSilly interior stuff but here is my Alphard steering wheel with a Lexus AB and SWC. My leather seat covers arrived...they go all the way back to the 3rd row. Looks soo much nicer than the 80's theme lookin' design on the OEM seats. (not sure if a GX option is offered but other than the arm rest on the front seat, should be the same??)
Did the 8020 rack mod with stock rails. Should be sufficient for what I need for now. View attachment 1772270
These are awesome, is there a write up on this mod somewhere?
Did you have to shave the length or was the 39.75 spot on? Also how are you going to mount items to the rails? I am planning this mod as well...Yeah, search for 8020 on GXOR. I got my extruded aluminum from tnutz (39.750" length) and then the hardware from 8020.
