I did get stuck in mud today. But that all my fault.Helps a bunch. Moving to the head of the list mt with at noise profile. Nirvana for my highway bias use case.
My experience is similar to @Spamcheese. About 6000 miles on my set of 5. I rotated them including the spare at about 4500 miles. No noticeable difference in sound. Still quiet for such an aggressive tread mud tire. I run mine at 32 psi. I tried 36psi, but was not getting full contact and harsher ride.@Spamcheese @gnarlytoes can I get a quick update. Specifically did the noise ramp up after they were on for a bit? Have you come to love the center ridge?
I have not had any issues with them. They sound like A/T tires still and traction has not been an issue.
I've been running a set of 37s for the past 12mon on my typically heavy 80. Red rock, sand, snow/ice and some mud usage. The comments about how quiet they are match my experience. Track well, quiet (just recently getting some hum @6k mi), and good looks. The chip, with sidewall protection shearing under hard use on rocks. Minor cuts and a few apparent cracks down between lugs. I run highways at 37psi, and have aired as low as 17. Previous tires were KO2's and Trxus. Disclaimer: I am reviewing these in collaboration with Milestar/Tireco. Review will air @ Offroad.com FWIW. My colleague, unbeknownst to me, is on his 2nd set of Patagonia's. He got ~45k on a Taco with the first set, and loved them. Mine also balanced with reasonable ounces. You could do worse for the $.
