i finally got around to replacing my head unit and ditching the factory amp. I had already installed door speakers so the idea was to use oem wiring to new amp and run RCAs from deck to new amp. Handful of wires what can go wrong?
I used a 20pin metra adaptor at the HU plug but the blue wire with white strip that’s is to turn on the amp went to a no connect pin on the OEM plug. So I tapped into the power antenna wire which the new HU also uses.
Key installed to ACC and radio works dome lights work locks work. Power mirror does not adjust anymore. Made a clicking sound when I first started the car like the mirror was folded but wasn’t sure if it was.
Remove key and nothing works, there is a red car flashing light under the radio with a wrench on it. No dome light, no power locks no alarm.
It’s 11pm so I parked it in the garage. Removed the amp power on wire from the power antenna wire on he metra harness. Same problems plus amp doesn’t turn on of course. Disconnect the ground wire in battery in case there is a short and called it a night.
Any ideas what I did? Tomorrow course is dis connect the metra harness from OEM plug and cross fingers it something simple. I also connected new HU ground to the ground wire in the metra harness vs hard connecting to a bolt.
