I need some input from the group on the best way to remove some beveled cedar siding on my house. I need to re-do the roof on a tool shed that was put on by the PO, but they obviously didn't know what they were doing. It's only 5' x 10', between the main house and the garage, very flat (2.5/12 pitch). No step flashing, no ice & water shield, so now it leaks at both ends.
The vent pipes are for the radon air & water systems, and ya stupid place to put them right under the valley, of course they leak now too. They will be moved, since I need to replace the sheathing too.
Cedar siding is ridiculously expensive, so I'd like to save & reuse the pieces that are on there now. Any suggestions how to get it off without destroying it? I have lots of pry bars, a sawzall, and an oscillating multi-tool at my disposal. Nails are stainless ring shank, very tough, difficult to remove. My experience has been that trying to pry them out from below the siding usually just tears the nail head thru the siding.
Should I just use a pin punch to drive the nails thru the siding, then caulk & stain when I re-install? Appearance isn't that important, this is the back of the house, and those spots are kinda hidden.
