Last night while working on my Cruiser installing Owl Courtesy lights I noticed my Key Fob would not lock or unlock the doors. It was hooked up to techstream to make sure that the Courtesy lights would turn on when the doors open and unlock. Which they were set to on according to techstream. Well after finding out the my drivers side wiring was putting out 12 volts and my passenger only 4.5 volts I tied everything up and decided to take figure out why my Fob was not working. I am able to start and the door buttons work. I switched out every fuse I could think of. Tried leaving my key in the ignition in the on position for 30 minutes. Check that the sunroof, dome lights, and windows all worked. Nothing is working. I have another set of keys that I leave with my dad just in case so I will try that today. But what is odd is the keys red light illuminates when the button is pressed as well as the security light on the dash. This tells me they are communicating. Is it an immobilizer problem? I searched on here for a match to my issue but there is nothing that I could find that is exactly like what I am experiencing. I have not be rummaging around with wiring other than removing the AHC fuses. So I am at a lose. Any ideas?
