Icon only makes these springs, i like progressive rates for ride.Prefer swapping to the correct height springs instead of band-aiding it. That said, the front is easy, we weld a spacer into the cone mount, within reason, can be any height. The rear is more of a challenge, needs to be machined.
Are they poly? I guess poly would be ok in the rear.I play around with spacers all day. Use what you need to level it out. Right now on my rig I have:
Driver front 30mm/10mm
Passenger front 20mm/20mm
On OMe front 418’s
Rear 30mm
On 850j’s
I bought my spring pads from eBay for $25 each.
