- Thread starter
- #21
If I punch it I can get a black cloud and boost does rise, but slowly. I'm pretty confident it's not fuel related.
So I've tried 2 more tests, pressurized the WG reference line with a bicycle pump, the actuator arm moves as it should, pressure holds till you disconnect the pump and release the air.
I also tried driving with the WG reference line unhooked, same lazy turbo performance, but boost would eventually climb past the 18psi mark I've been stuck at since the issue began, I saw as much as 22psi for a second. I hooked the line back up right away after the test.
I'm thinking I'll try and pull the downpipe and dump tube off the back of the turbo, pressurize the WG reference line with the bike pump to open the WG, and see if I can see and remove whatever is keeping the WG flap from sealing.
Ya, Graeme agreed it sounded like a WG issue based on the symptoms, so I really don’t know what to look at next. It’s like 5AM there now so I’m hours from hearing from him if he’d even look at this kind of thing on the weekend.
Hmm.... broken wastegate spring?
Easy way to find out if your waste gate actuator has failed is to unplug the hose at the actuator and go for a short drive around the block. Be careful because you won't have boost control but you'll know if your boost will climb fast or still lag when laying into the throttle. It's how I tested my actuator and misdiagnosed my leaking boost issue right before I discovered all the loose manifold nuts while reassembling the intake pipe.
It sounds like you have it sorted Ian? Something I saw many years ago, I fitted a turbo on a 2.8 Capri, car went like a scorched cat. A week later customer returns symptoms as yours, checked everything that had been fitted, all good.
On a chancer I disconnected the exhaust, engine revved great and went well....complete with flames under the car from the open down pipe!
Turned to be one of the perforated tubes passing through a silencer had broken, this dragged down a load of wadding and virtually blocked the exhaust, it was passed it's best, new exhaust job done.
Regards
Dave
Get a pic of the top (large) part of it. Often aftermarket controllers can swap out springs and are designed to be disassembled to swap them. If you get the make its just a matter of finding what weight spring you want.
I'd contact gturbo for advice on a replacement. I'd be asking for the design and get a wastegate from kinugawa or something that's designed to change out different springs. You could find it out in your own by comparing pics but I've wasted a lot if money with trailing and error.
If boost didn’t taken off when you took it for a spin, with the waste gate actuator hose off, then something else is leaking. Unless the waste gate is being forced open even with the hose disconnected on the actuator it might be upstream from the turbo.
