I'm working on likely a 77 FJ40, kind of a hybrid setup I have replaced all the rear wheel cylinders, the front calipers and the hoses, I have inspected everything for leaks. I had a replacement LC master cylinder and a LC brake booster,, some kind or device to regulate the rear brakes stock thing. The Booster was replaced with a mini truck booster (wouldn't hold vacuum) and I have tried a new Mini brake master cylinder as well. so no blocked lines etc., all was bench bled properly and the rest of the system bled, I adjusted the plungers some but it doesn't seem to change things.
Symptom's' When you push the pedal with the engine running the booster in play the pedal goes to the floor will not harden up. Keep in mind I have rebuilt maybe a dozen brake systems on Land Cruisers, always able to solve problem.
So
Bad new wheel cylinder in rear?
3 bad master cylinders in a row?
I'm sure its right in front of me but I'm getting older so WTH is going on,, Cheers in advance, Larry
So
