So anyone have this install before with installing the axles back in their Fj40 after a locker was installed?
I have a very intelligent and analytical man rebuilding and setting up my rear diff with my original locker from my other rear end that is no good.
The locker is about 12 years old. The locker itself was rebuilt about 8 years ago and hasn’t been used since
The locker is an Eaton full Detroit locker some call it a soft locker
Ken Fransisco is a very awesome guy who when he does the work he’s focused and like an engineer very intense what he does in the work and math etc
We know him here as Zuk.
Well we’ve come up against an interesting issue... which Zuk is going to help me with on his time
Attached are images of the problem
How would I get my axles in? Can’t seem to remove the bolt bolt that holds the center pin/ bolt (crosspin?) in to install c-clips with out losing preload on the adjusters? I thought of a way but heres what the issue is as follows images taken with my phone but should be focused enough
Zuk will be heading to my place on his own to help me do this, he is adamant I don’t try myself.
I can say is if I had to do this myself and remove the carrier bearing cap and try, I may mess up... maybe. I don’t think I’d lose the preload since the other side is still bolted down... but things don’t always go easy for Izzy (that’s me)
So I am wondering has anyone had this issue before?
The locker I believe is old but I really don’t know except over 15. I believe the rear end in my 1972 Fj40 was a later model rear end because the pinion gear on the original rear end is/was fine thread.
Thank guys and ladies for any info you may have had trying to do this
