So I read all the threads about swapping out the lower ball joints and its seemed like a fairly straightforward process... until the lower ball joint refused to separate from the hub. I have wailed on this thing forever. I had to suck up my pride and drive my wife's car to work yesterday. She wasn't very happy about that nor the prospect of me doing it again today!
Any special tricks to getting this thing off? I tried compressing it with the big ball joint compression c-clamp with no luck. I have a BFH and have been beating on it like a mad man. It wont budge. If the ball joint threads were still in good shape I'd put it back together and pay someone else to do it!
Maybe I'm just missing something here? I have a pickle fork and the gap between the hub and control arm is too much to make a difference. I've basically used the pickle fork and a chisel on the hub where it meets the ball joint. I've also beat on the joint from below.
I have not tried putting the jack under the actual ball joint and raising the control arm that way to put weight on it. Planning to try that and also heat it up with a torch. Maybe? Should the control arm be supported by an jack or not???? Should the upper be completely disconnected? why won't my axle slide all the way back in!? Argh!
Thanks in advance and sorry for the somewhat slopping rant and process description! Any advice will be greatly appreciated! Its an LX470 with AHC in the low position ( I can change that before I go back out there if it matters, I loosely reassembled it and put the tire back on)
