Can you order additional connectors or pins for the stock interior fuse block? I would like to add some circuits to it.
Can you order the pins from toyota?The simple answer is yes you can
YesCan you order the pins from toyota?
What about something for the under dash fuse box? Those look like they will work for the under hood fuse box.
Not sure about that. It's the only Blade Fuse terminal that shows up in my harness repair manual.What about something for the under dash fuse box? Those look like they will work for the under hood fuse box.
