- Thread starter
- #41
Some more progress, furniture is done! Now time for the electrics & heating
Two question for you guys:
1) How do you boil water for a quick coffee on the road? I was planning to use a small electric kettle. But these little bastards are all rated at 750W+ but my inverter is a modest 300W. Lighting the stove seems like such a hassle, but upgrading to a 1000W inverter an overkill. Options?
2) Have you HZJ75 people out there kept the 24V car voltage for household power or stepped down to 12V?
The previous owner built a system with two household batteries which are charged through the altenator and/or solar panels, controlled by a battery isolator and a solar charge MPPT. Power users in the back are an Engel fridge 12/24v, a couple of LED lights, a few USB charge points, a Shurflo pump, Eberspacher diesel heater, (an electric kettle?) and a 300W pure inverter for 230V output.
View attachment 1726020 View attachment 1726021 View attachment 1726023 View attachment 1726024
Looks great. How are you securing the assembly to the Troopy? Just bolting straight through the body? Or using the rear seat mounts?
Lets see who finishes first , but I have a hard deadline on august 1st when our trip will start, so the pressure is on!Nice job Paul.
Very clean , and logic .
A little bit more and your almost
Bye Renago
nice troopy! is your fold down step bought or built? I need to buy or make one of those... could you take some photos of how its attached and the angles folded up?
cheers! I found it. looks like it will work well enough. i think the toyota gods will forgive us given they didn't make one themselves and because the part doesn't leak oil or cripple the vehicle when it breaksIt's actually the ONLY LandRover part on the car Works perfectly and is pretty cheap (£30 including shipping). We usually keep in folded down, but in the folded up position the doors can still open and close. Had to drill some holes in the bumper for fixing it in position.
Great set up. Are you using the area behind the cabinets in the rear quarter panels for anything? Lots of empty space usually unused by most.
