I am looking for CB antenna recommendations. I have a Cobra 75 WXST freshly installed that hasn’t been tuned. I absolutely need the best range possible because I will be leading a 12+ vehicle convoy west to Colorado. I need maximum range for on the road and trail.
I know CB’s aren’t the best choice for range but it’s what the convoy has agreed upon so that’s what we are working with.
I have a 5’ heavy duty Firestick already but I am willing to switch. I also have a confirmed good ground through the bumper. I scraped paint and it was checked for continuity. I am running a heavy antenna spring and no quick disconnect.
I saw a firestick style antenna that has an extendable whip from the top at the truck stop. Is this a better option for range extension? If I go that route I assume I need to tune it with the tip extended, more length doesn’t just mean more range with CB’s if I recall.
The 5 footer I have now is way high above the roofline but it’s heavy, I am worried it will be occilating at highway speeds (80mph) and whipping around even with the heavy spring. Should I go with a lighter duty 5 footer or consider the extendable whip I saw at the truck stop? Function is paramount, I have a Wilson magnet mount whip but I’d prefer the front bumper mount.
I would consider a dual antenna if there’s a real benefit (not a juiced up CB radio) and if the install isn’t a big deal. I have no idea about dual antennas, I just know that’s what truckers run.
Pics are of current set up. I promised @ForrestGrump pics of where the dongle for the radio exited into the passenger footwell and figured I’d open it up in a new thread for antenna recs.
What has worked for any of you off the front ARB bumper?
