- Joined
- Sep 25, 2011
- Threads
- 84
- Messages
- 3,631
- Location
- Harbour City, the New Southern Wales
- Website
- www.freewayoneentertainment.com
Git'er runnin!
Was talking with @SFROMAN about this earlier today. Mechanicals only. Pressure wash the body, but I wouldn't do anything else.
Have the OEM radiator hot-tanked and pressure tested. If the fins aren't corroded out of it, it's probably fine for a good long while.
How close does that Dupli-Color match the original pewter? Want to retain the original on my glovebox, t-case lever and ashtray, but will need to paint the seat frames and gauge surround. Not necessarily looking for perfection, but close would be good.(Dupli-Color BMG 0490)...had to go to 3 different auto parts stores just to find 3 cans - 1 from each store.
The new turn signals I bought a few months ago are a very good match to the original paint I found on the glove box and ashtray. So if you can compare those, that should give a good idea.It’s tough to tell as my glove box (and everything else in this truck except the glass) is painted yellow. I can compare to new turn signal lights from Toyota if that helps. I'm going to try that citri-strip stuff on a couple parts tomorrow and if it works I can compare to those.
