welcome aboard. Details on the 80? Looks clean.
One owner, one city car serviced by the same two dealerships it’s entire life. Has 137k miles. Body, paint and mechanical of great shape. Interior needs new wood and leather. Planning on redoing the entire interior when it gets delivered.welcome aboard. Details on the 80? Looks clean.
Installed this - FTM-400XDR and finished up the rear bumper build. I will hide the wire on the radio once I am sure its in the right spot. Built up more of these too - EGR temp sensor plug.
View attachment 1683795 View attachment 1683796 View attachment 1683798 View attachment 1683797
Rear bumper looks great
What kit exactly?Did little things, worked on the rear hatch rust, just a temp cosmetic fix, and fixed the couple small cracks in the dash with the permatex kit, will probably end up redoing one spot that did not come out as nice as I'd like. Also, drove it to work in nyc today, did the dash on breaks.
Bumper looks great, which one is this?
Buttoning up a front axle rebuild. Found lots of things the PO ****ed up. For example, all the flange plate washers (between the cone washer and the nut) were missing on both sides. Didn't even know they were supposed to be there until I saw it in the FSM. Anyone know where to get 6 of those?
Also, set the wheel bearing preload with the Torque to 43 ftlb, rotate, loosen, torque to 43 ftlbs, loosen, tighten to 10 ftlb, measure with fish scale (10 lb). Then lock it down and remeasure with fish scale. But somehow after installing the flange, and re-installing wheel spacers, the preload is now up to 30-40 lb? How did that happen? Now I'm gonna have to pull the flange again and do it all over.......
The Vinyl / Leather repair kit. - lesson learned is don't put the adhesive on the dash if the dash is too hot. it sets up too quick to remove excess if you use too much. got it at the hardware storeWhat kit exactly?
Put in all new soft lines, brake pads, added a cam latch for the Campteq to hold the top down and then the FJ40 flat towed the 80 to Camelback Toyota to get a new transmission. Good times...
That was awesome!!!! Glad little Superman was there to enjoy the ride!Climbed the waterfall at SMORR (Southern Missouri Off Road Ranch) this weekend. Video quality is terrible because my buddy texted it to me.
https://m.facebook.com/story.php?story_fbid=10214089610347309&id=1623927727
*edit: I need to work on the link...will get a youtube link up since facebook isn't working
