Thanks chalky,Hi nikolatesla
see if any of these pages help you.
sorry some of the pages are upside-down but being from down-under that should not be a problem for you.
mine is a 1999 LHD v8 4.7 but most looms and parts are common. This should help you work through the issues.
if you need more because you think it will help just shout.
I have more problems with left or right (hand drive)
That is very similar to mine ...I think.
I have those manuals in my "archive" of but i don't have the specific manual for the auzzie one which is a live axle straight six petrol engine.
The only manual i have is a haynes one covering diesel ..manual..and is rather scant on detail.
It had always amazed me how even the owners manuals these days cover many different models and are like bibles .
I think we deserve better ..i digress.
From scanning the net It seems that the fuel pump ecu is in the fuel pump .
I will be able to by pass this but i don't know if the main ecu regulates fuel pressure via the fuel pump ecu.
It may not matter as an emergency measure .
Just to recap
Disconnecting the Transponder Key Computer plug which is behind the drivers side vent , enables start but not run due to fuel cut off....spark is there so in theory one could put a tank on the roof and siphon fuel (via a tap)into the throttle body(mine is mechanical) and get to saftey. I have done this before (Manual fuel injection) in a old van i had.
I have no way of knowing if there are implications for other things like transmission ...but i will keep on this and again any body with experience in fuel pump ecu please chime in .
And Chalky,if you could test this on your American V8 we will know if it applies more globally.
basically you have to dig from the bottom of the dash and remove the ac vents. Its fairly non destructive (no plastic snapping)
If a moderator wants to move this ,and a few posts above ,to another thread called Emergency
security bypass ,it may be appropriate here as this may get long and slightly off topic .Just a link the new thread would do .
