So in the process of replacing both valve cover gaskets I dropped a valve cover bolt down into the engine bay and it did not make it to the floor. After 30 min of searching I finally dropped the large plastic skid/belly pan and finally located the bolt....I also discovered on the DS the large clamp that I assume is supposed to be around the boot is popped loose and is just spinning around the "inboard joint tulip" housing of the axle.
It appears that it has not leaked yet, everything is still dry. Is this a situation where I can just hose clamp it and move on?
Thanks in advance...
